    Apr 2007
    New Zealand
    Hi all!
    I'm a mac user, and I need some help how to make rmvb files to mp4?
    If anyone knows, please let me know!!!
    Thanks very much
    Have you tried ffmpegx? it should support rm/rmvb.
    Apr 2007
    New Zealand
    Hi
    I tried it before, but doesn't work. Actually, it suppose working. However, I don't know how to make it. If you know, please tell me! Also, if you can, please provide a specific process for me!
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Reading rmvb files in ffmpegX requires the mencoder engine; the iPod profile requires the ffmpeg engine. Unfortunately, for the moment, that means encoding twice: first encode from rmvb to anything ffmpeg can decode (e.g. XviD), then encode that to an iPod format.
    If you use the XviD mencoder preset for the first run, with a high bitrate/low Qmax, then the quality could be well preserved.
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    wouldn't simply hijacking the file as it plays in
    Real Player with iShowU to mp4 be much simpler?
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
