Basically what I'm looking for is a simple filter for VirtualDub which searches for timecode data in a DV stream and pastes it into a corner like a proper camcorder might. I'm sure this is a commonly-sought capability. Primarily I'm interested in determining whether or not the Digital8 camcorder I'm using to move 8mm/Hi8 videos to the PC is bothering to do anything with the timecode information which may be extant in said videos. Forcing VirtualDub to produce a visual representation of the DV video's timecode would be a convenient way of accomplishing this, without having to, say, let Premiere Pro spend 12 hours building peaks on a 27GB file.
Thanks in advance.
There are a few datecode programs in our DV tool page: https://www.videohelp.com/tools?s=33#33
There's a filter called AddFrameNumber.vdf available from Thomas Hargrove that should do what you want. A google search should locate it for you.
Buy My Books
Virtualdub and Filter Related problem
By frmys in forum EditingReplies: 26Last Post: 27th Jan 2011, 13:16 -
VirtualDub: Layer Filter
By creamcone in forum EditingReplies: 6Last Post: 26th Dec 2010, 12:27 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 10:48 -
VirtualDub Filter Blending
By sambat in forum EditingReplies: 4Last Post: 6th Sep 2009, 15:07 -
VirtualDub Filter During Capture?
By CosmicOutburst in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2007, 19:48
