Hi everyone.
Is there an alternative to http://www.antennaweb.org/ for looking
up your antenna channels ??
The antennweb website has been down all weekend (because of a yahoo issue)
and there doesn't seem to be any notice when it will be back up and running.
Long story, short..
You see, I need an updated listing since I threw out my one year old printout and
I can't remember all the numbers. Unfortunately, my WinTV-HVR-1600 does
not seem to give regular numbers, instead, it uses 4-digit numbers, and these
do not match the 0-69 usuals. So, what I do is hook up the antenna to my
receiver and let it tune to the stations that I'm trying to focus on. Then, I
will re-connect my WinTV-HVR-1600 and the antenna cable.
Thanks,
-vhelp 4262
Here's one channel listing for NY State: http://www.lnl.com/howto/nyshdtv.htm
Try http://www.tvfool.com/Originally Posted by vhelp
_______________
Chuck -
I have a 1600 as well and its been working great. The 4 digit numbers it defaults to is just a 1 infront of the channel. For example, channel 2.1 digital is 1021. Channel 32 is 1320. What program are you using to view/record TV? I tried everything with the Hauppauge and found Vista MCE to be amazingly easy. Snapstream Beyond TV would be an adequate and cheaper solution. Both provide guide data built in. Snapstream has a free trial as well.
Need Alternative To Roxio
By mlb32704 in forum Newbie / General discussionsReplies: 23Last Post: 9th Apr 2011, 19:50 -
Dr. Divx alternative?
By jaicassidy in forum Video ConversionReplies: 3Last Post: 5th Dec 2010, 06:21 -
FixVTS alternative
By hardy in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2010, 04:05 -
Alternative to Premiere 6.5
By Diving Mullah in forum EditingReplies: 8Last Post: 15th Mar 2010, 11:41 -
flip4mac alternative????
By hndsmman in forum MacReplies: 4Last Post: 9th Nov 2007, 14:41
