I've been using VSO's ConvertXtoDVD software for a couple of years now and I've noticed it's very temperamental. When creating a DVD from a single file I usually have little or no problems but when I try to create one out of multiple files or something longer than 2 hours I get either a bad voice sync or a jumpy video that skips every couple of seconds.
I'd like information on how to either fix my converter so I can get a good 3 hours to a disc or let me know the better converter I should be using. I just want things as painless as possible. I consider myself a moderate user in that I understand a lot of the concepts of the different encoders and such but I'm not ready to make a DVD from scratch using bit rate calculators and such.
Any help you can give would be really appreciated
You shouldn't. IMO, 2 hours of Video DVD in decent quality is max on a DVD-5Originally Posted by aeuzent
/Mats -
well good is in the eye of the viewer.
to some people, nothing less than retail DVD quality is good enough,
and others think KVCD is good, those that like KVCD will think 6hrs on a DVD looks good
I think the majority of us fall 'in between' those two examples -
I have made some vids with over 3 hours of stuff and had no problems with convertXtoDVD.It helps that the various vid clips are the same format and same screen type. You no not one thats was made in wide format and one that was full screen. If you mix those you will have some problems. I know i tried it and it doesn't work to well. DVD flick does work pretty good but it's slower in my opinion. I'dd stay away from winavi its garbage compared to ConvertXtoDVD
looking 4 FX creator 4 dvd/br interactive menus
By cesarin in forum Authoring (DVD)Replies: 0Last Post: 30th Dec 2011, 09:55 -
Imtoo dvd creator
By fromunda kid in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2008, 21:22 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
SUPER DVD CREATOR 9.25.0 Question
By Jboogie70 in forum Authoring (DVD)Replies: 2Last Post: 24th Aug 2007, 06:53 -
Audio DVD creator software
By bryankendall in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 15:45
