    Apr 2007
    Spain
    Hi,
    The new version of ccextractor, which I just uploaded to sourceforge (as usual, source code plus windows and linux binaries are included) can produce .srt directly from your digital recordings or DVDs, so you no longer need to use additional tools.
    You can get it here: http://ccextractor.sourceforge.net/
    Use example:
    [E:\TransportStreams]CCExtractor.exe -srt Sopranos.S06E15.ts
    CCExtractor v0.17, [...]
    Input: Sopranos.S06E15.ts
    [Raw Mode: Broadcast] [Extract: 1] [TS mode: Auto]
    [Debug: No] [Buffer output: No] [Buffer input: No]
    [Autopad: Yes] [Print CC decoder traces: No] [Target format: .srt]
    Creating Sopranos.S06E15_1.srt
    File seems to be a transport stream, enabling TS mode
    New video information found at 00:00
    [1920 * 1080] [AR: 03 - 16:9] [FR: 04 - 29.97] [Bitrate: 2250000 bytes/sec]
    Done, processing time = 91 seconds
    Length according to PTS (MM:SS:100s): 3475 (57:55:791)
    A sample of the output:
    13
    00:02:53,239 --> 00:02:56,242
    T? THE FEDS ARE DOING
    SOME DIGGING OVER
    BY BRANFORD AVENUE.
    14
    00:02:57,310 --> 00:02:59,813
    WILLIE OVERALL--
    THE BOOKIE,
    15
    00:02:59,879 --> 00:03:01,414
    LABOR DAY, 1982?
    May 2007
    Chicago, United States
    Will this work against mpg files?
    Apr 2007
    Spain
    It only works with MPEG files.
