I need to change an IMG file to something that can be read in my dvd player.
I was told that I could just burn the file to a dvd and then play it in my dvd player, but apparently my dvd player can't read it. Can anyone help, please?
Cheers
If you put the disk you made into your PC, what shows up when you click on it in Windows Explorer?? My guess is you'll see the single IMG file ... indicating you burnt the FILE on to a DATA disk rather then burning the IMAGE itself.
Using Nero?? Try the BURN IMAGE option (under the RECORDER menu I think)
Or try the (freeware) IMGBURN program (switch to WRITE on the MODE menu)
Trev -
Thanks for the help everyone...
I have now solved the problem...
Cheers
How to obtain a tiny sample of an *.img file from a huge *.img file
By lousk in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 09:03 -
Feedback: vbulletin, [img][/img] tags not working.
By vhelp in forum FeedbackReplies: 5Last Post: 28th Jan 2010, 00:51 -
img test
By waheed in forum TestReplies: 26Last Post: 9th Jan 2010, 11:44 -
Converting ISO/IMG to AVI: How to choose the desire audio track ???
By htp367 in forum Video ConversionReplies: 3Last Post: 19th Jul 2009, 13:11 -
Extension .IMG
By Jomapil in forum ComputerReplies: 7Last Post: 17th May 2009, 09:52
