I have a mkv file that uses h264 codec. I used MKVExtractGUI to extract everything. Then I used avc2avi to convert the raw h264 to avi then I merge the audio & video in virtualdub but when I play it the audio is unsync. Why is that?
Maybe a h264 with variable frame rate(vfr), see https://forum.videohelp.com/viewtopic.php?p=1656988#1656988
Whenever you have audio sync problems the first thing to check is your fps, are you working with a pal or ntsc video?
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
unsync video
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 08:00 -
Portable DVD Player Audio/Video Unsync Problem
By wicious in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2007, 09:14
