I recently had family movies tranfered from 8mm film to a DVD through a professional service. They did a great job with a nice menu. The problem is I labeled the reels in what I thought was the correct chronological order. I was wrong. Can I reauthor the DVD and put the reels in the right order using the existing menu? The chapters are labeled reel one through reel eight. You can click on the individual reel/chapter or watch the whole DVD. Also, each chapter in the menu has a preview window. Can I switch the chapters and change the text for each chapter? Thanks
Easiest would probably to remake the entire menu using Tmpgenc dvd author, select add dvd video and add your old dvd video.
You could try use DVD Remake Pro to remake it using the original menu.
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
