Hey, I just want to encode the credits of my DVD so I can preserve the quality of the movie. How do I reencode only the end credits and nothing else using CCE and DVD-Rebuilder? Thanks!
Hi-
http://forum.doom9.org/showthread.php?p=8647551. Run a "No Compression" PREPARE.
2. Open the REBUILDER.ECL file and another new file with Notepad.
3. Cut and paste the header (the first couple of lines) into another text file.
4. Move down the REBUILDER.ECL file until you see the section (starting with "[item]" that relates to the cell you want to encode. Cut and paste that section also.
5. Save the new file as "encode.ecl"
6. Then you can open CCE manually and encode just that section. It will overwrite the M2V file extracted in PREPARE.
7. REBUILD
If you're saying that the movie is just a little bit over the size of a DVD5, and reencoding just the credits to a smaller size will allow you to then fit the entire movie onto a DVD5, in my opinion it would be easier to do it yourself manually, outside of DVD-RB.
Extract the cell containing the credits using PGCDemux. Reencode them. Remux them using Muxman, creating a little DVD of just the credits. Use the "Replace" button of VobBlanker to replace just the cell containing the credits. -
^ sorry I didn't realise.
I'd fork out for the pro version, its got more options for tweaking.
How can I split 10 GB divx movie into 4 parts?
By andy99 in forum EditingReplies: 3Last Post: 2nd Oct 2010, 17:05 -
Splitting a Movie into two parts
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 23:25 -
Joining a movie with 2 parts together using virtualdub!!!
By SaM*T in forum EditingReplies: 1Last Post: 17th Sep 2007, 15:09 -
burning 2 parts of movie to 1 DVD
By popgun2k in forum DVD RippingReplies: 2Last Post: 27th Jun 2007, 10:07 -
how to rid discolored parts of movie
By tranzadikt in forum RestorationReplies: 3Last Post: 14th Jun 2007, 09:06
