Basically I have a DVD that's 3 hours on a 4.7 gb disc
I ripped the DVD to mpg using Roxio and the output is 12.73 gb. Is this normal?
So I converted the 12 gb Mpg to AVI using Sony Vegas and the output is 26 gb !!?
Am I doing something wrong of Roxio and Vegas just produces big files?
I also used Xillsoft to rip the DVD direct to AVI and the result is also above 20 gb.
Basically I just want to rip the DVDs to AVI with minimal visible loss of quality, and file sizes that's almost the same as the DVD.
No, just ripping mpg out of a DVD should land lower than the size of the VOBs.Originally Posted by kamill
AVI size dependson bitrate used when encoding, so this is "normal", but you've must have used an unusually high bitrate.Originally Posted by kamillRip with DVDFab Decrypter, encode to AVI with AutoGK, where you can set whatever bitrate/file size your heart desire.Originally Posted by kamill
/Mats
Getting two fatal errors when extracting mpgs from vobs
By Antony in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Apr 2012, 01:24 -
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 23:37 -
Join several mpgs together
By milway in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 21:49 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 14:35
