I've been all over the web w/out success.I need to know if there is any way to use a Sony 8mm handicam with an ATI tvwonder as a webcam.Can't get netmeeting to recognize my video.Are there any similar programs?ANY help would be GREATLY appreciated.Thanks![/b]
Yes you can use any video camera as a web cam. TVeo is another web streaming product that you can use.
The problem I have had with web cam is that my camera has an automatic shut off after 10 mins. -
Thanks Thurbs I'll check that out!My cam was also shutting down after being innactive for a period of time.I changed something in the menu to fix this but,do not recall exactly what.
