as you know, DVD standard support vcd-mpeg1 file, and I have authored such a dvd using mpeg1 files, without video re-encoding. but waite, the audio sample rate of mpeg1 encoded file is 44.1khz, and I noticed that the dvd I have authored has a sample rate of 48khz. I'm not sure whether DVD standard allow 44.1khz audio sample rate for mpeg1 file. can anyone make it clear? Thanks.
btw, the authoring software is TDA3.
That's correct ... VCD framesize is supported by DVD specs, but the audio has to be 48KHz samplerate!
Check WHAT IS DVD on the left
Trev
DVdate: DV-AVI Type 1> 2 conversion unexpectedly altering audio sample rate
By simonm in forum Video ConversionReplies: 1Last Post: 4th Nov 2010, 08:54 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 14:32 -
DVD Audio To .wav Sample Rate Question
By xtreme469 in forum AudioReplies: 3Last Post: 29th Sep 2007, 09:04 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 13:59
