Hello. I have some SD video that I would like to upconvert to HD (I can put up w/ 576p). Is there any software that can do this, and if so what it is and how to use it for this purpose.
Thanks in Advance,
Matt.
A qualified "kinda, sorta", but it is slow and doesn't look quite right (to my eyes, at least)
http://www.thedeemon.com/VideoEnhancer/ -
Ok. I wanted to convert a SD video file into HD. I doubt that my computer would be able to handle such a task. Out of my curiosity, how much would upconverting hardware cost?
http://www.pcpodcast.org (Website Under Construction) -
It could. Slowly. But as asked before, why? What's the point? -
You have the same CPU as me, but half them memory. I tested VideoEnhancer on my system, and a 90 movie took 11 hours 30 minutes to process. And that was just resizing up to DVD spec. The quality difference between video enhancer and avisynth's lanczos4resize function certainly was not a justification of the time difference. Perhaps resizing to 720p would show a greater quality difference, but it would also double the time required, so 24+ hour encodes would be something you would have to get used to.I doubt that my computer would be able to handle such a taskRead my blog here.
analog upconverting
By jaybird in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2010, 21:20 -
HD and upconverting over component?
By RoyGBiv-inRI in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Jul 2009, 19:40 -
When upconverting doesn't
By Seeker47 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Feb 2008, 13:34 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 16:42 -
upconverting vhs etc
By victoriabears in forum Newbie / General discussionsReplies: 10Last Post: 11th May 2007, 02:38
