I am just moving into the world of European dvd imports, and I visited your hacks page and found the hack that enables my Coby 224 dvd player to play dvds from different regions. When I tried the hack, the proper menu appeared, and I could select "region 2," which is what my newly ordered dvds will be.
But here's my question: does the Coby 224 convert the PAL format to NTSC? A friend told me that even though I can select the different region codes on my dvd player, the output might not be playable on my NTSC tv. I checked, and the dvds I ordered are in the PAL format.
I really like my little Coby and hope to keep using it, but I'm worried that this won't work! I can't test it yet as my dvds are presently in the mail from amazon.co.uk. I want to be prepared because I know I'm gonna want to start watching the dvds right away when they arrive in a week or so!
Thanks for any help/ideas you can offer.![]()
From a quick googling it looks like your dvd player can convert to NTSC on-the-fly:
http://www.popularelect.com/product_info.php?products_id=36Code:Coby DVD224 DVD Player: * Plays DVD-Video (NTSC and PAL), MP3 CD, and JPEG image CD * Dolby Digital and DTS 5.1-channel surround sound through coaxial or optical digital-audio output (for use with compatible receiver/speakers) * CONVERT a PAL DVD disc to NTSC for viewing on any USA TV * CONVERT an NTSC DVD disc to PAL for viewing any USA (or any NTSC) disc on any PAL TV * TURN OFF the conversion and it is only a CODE FREE PLAYER so you can use any PAL-NTSC TV and see all DVD movies in their original quality with no loss due to conversion. * It is also 100-240 Volts automatic, very small and lightweight so excellent for traveling. * Super Slim Progressive Scan DVD Player -
I will have to give it a go when the discs arrive and see if it works. It's funny that the manual doesn't mention the PAL to NTSC conversion thing, but oh well.
Thanks for your quick reply.
DVD Player Converts PAL to NTSC
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2011, 19:56 -
COby 224 Hack Problems
By cinefile in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Jul 2008, 04:30 -
Cheap, reliable ntsc/pal dvd player?
By BIFFtheSTIFF in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Feb 2008, 22:44 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 08:40 -
Broken Remote Coby 224
By Helrich in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Nov 2007, 19:34
