I am currently running 7.1 with my all in wonder Radeon and I am having problems with frames dropping and my vcd quality is terrible. So my question is should I upgrade to 7.5? If so whats the best way. Do I add remove then delete all the reg stuff the reload or can I load on top of 7.1. Also what is the best capture software to use? I am try to convert a few of my home movies to VCD and was able to create them but the quality sucked. I am using the ATI capture stuff with the custom VCD profile and I used the reg tool to fix it so it is exactly 2.0 complaint. So what is the best way to get the highest quality vcd possible. Do I save as AVI then convert or a save as a mpg1 with higher bitrate then convert with tmp or save as mp2 and covnert to mp1 if possible. Any input or suggestion will be greatly appericated.
Results 1 to 1 of 1
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 13:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
