  1. Hi all-
    I've recorded several student created presentations over the year which run from 3 to 5 minutes. I burned these clips with ConvertXtoDVD and it plays fine. ConvertX creates a title for each clip which was fine until I had to search within each clip to find a particular student presentation. Is there a way/program that will allow me to go directly to a particular presentation within each recorded segment? I spent half my time last night trying to find presentations for parents that had included their children-what a waste of time, let alone unprofessional :>(
    Any help would be greatly appreciated!
    Mark
    Aug 2004
    Yes you can reauthor the dvd and manually insert a chapter point wherever each presentation begins. Create a menu that will help navigate to each presentation.
    Extract the clips, which pgcdemux can do. Then a number of dvd authoring progs out there can do what you want. Personally I use dvd lab pro, but I am pretty sure the freeware gui for dvdauthor can do it.
  3. Thanks, I'll give it a try and see what happens!
