Hi!
Does anyone out there know if there's a dvd recorder that makes it possible to capture say a composite source which is being played in ntsc but have it automatically convert to pal within the dvd recorder?
my preference is for pioneer dvd recorders but i can't seem to see if this is possible from their web site.
Typically they record in the same format as they receive. So I suspect, what you really need is a dvd recorder that can play NTSC discs and output to PAL. (Typical NTSC to PAL conversion).
Google is your Friend
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
dvd recorder that records PAL and NTSC
By ecc in forum DVD & Blu-ray RecordersReplies: 4Last Post: 8th Jan 2009, 03:53 -
Pal/Ntsc DVD Recorder question
By ArtieEngh in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 11:18 -
How to record NTSC on a PAL dvd recorder?!
By Dekaspace in forum Newbie / General discussionsReplies: 8Last Post: 4th Jul 2008, 00:21 -
PAL VHS to DVD (NTSC) thru combo recorder
By valkoles in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2007, 01:57
