i edited out parts of a DVD with DVD Shrink. What would i use to add tranitions between the parts and make chapter points and menus.
thanks
If you want transitions you need an advanced editing tool like mpeg video wizard dvd.
DVD Lab is a very good authoring program with a lot of capability yet it is relatively easy to use. The on line manual is very clear with a lot of info in it. One feature that I like about it is it allows you to import VOB files. It has an assets box into which you drag the elements that you intend to use to make your menu with. When you drag an element into the assets box, it automatically inspects it to insure that it is DVD compliant. In the case of VOBs, it will also join multiple VOBs into one joined VOB which makes the authoring process straightforward. When you finish and create a DVD, it creates VOBs that don't exceed the 1MB size specified for DVDs.
DVD authoring question...
By mjl1297 in forum Authoring (DVD)Replies: 8Last Post: 12th Mar 2011, 10:26 -
dvd authoring speed question
By slaak in forum Authoring (DVD)Replies: 0Last Post: 25th Jan 2009, 13:14 -
dvd authoring question
By ht0160 in forum Authoring (DVD)Replies: 1Last Post: 7th Jul 2008, 16:52 -
Another DVD Re-authoring Question
By videopoo in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 02:40 -
New to dvd capturing/authoring… Question
By tygger in forum Authoring (DVD)Replies: 7Last Post: 18th Jun 2007, 13:17
