what I would like to do is take the music off a DVD without the voices and sound effects. Is there a way to do that or is it impossible because they are merged together in the audio track? I know you can buy "sound tracks" on DVD but those are just the songs used. I am talking about music from TV shows like star trek or mission impossible. thanks!
From TV, pretty much impossible. From a DVD with Dolby 5.1, you may have a little better luck with one of the channels that has more of the music on it, but the voices and sound effects are likely on all the channels to some extent, along with the music. If the music was separated to just a single or even stereo channels and no other, the DVD wouldn't sound right.
There are filters that help to separate music from vocals, but they rarely work that well.
You may be able to find some TV or DVD theme music for those videos or shows if you look around, though. -
Keeping Voice, Removing Background Music How?
By Teac23 in forum AudioReplies: 4Last Post: 26th Feb 2010, 07:01 -
Do do I keep the voice and soundeffects but strip out the music on a DVD?
By mbeaumont in forum Newbie / General discussionsReplies: 0Last Post: 12th Feb 2010, 17:15 -
Music Play Over Voice Separation Info Please?
By Teac23 in forum RestorationReplies: 1Last Post: 2nd Feb 2010, 08:23 -
voice and music recorder
By zoobie in forum AudioReplies: 9Last Post: 17th Mar 2008, 11:51 -
How Can I Separate DVD Music & Commentary's Voice?
By Aaron1927 in forum AudioReplies: 5Last Post: 10th Aug 2007, 18:28
