Making a multi-episode DVD. Using 2 pass encoding (force of long habit). File #4 fails on second pass and comes out with only 10 encoded frames. With single pass, it is OK.
This is the 2 pass (error) log:
svcd2dvdlog-20070426150031.txt
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
And this is the 1 pass (OK) log:
svcd2dvdlog-20070426213610.txt
[Added info.] Have since had this same error on a different file.Dwight
- Herm Albright
Ok. I will take a look at this... In the meantime can you stick to 1 pass?
Yes, 1 pass, no problem. The 1 pass quality is really surprising compared to past experience and other encoders.
I'll hang onto the files that errored out in case you need them.Dwight
- Herm Albright
ChrissyBoy-
Just passing along a cosmetic issue:
Dwight
- Herm Albright
ChrissyBoy-
Should I retry the files I errored on with the new build or is that something I should wait on?Dwight
- Herm Albright
Sorry Dwight - not had time to sort that out... Single pass for now i'm afraid.
thanks for the typo headsup!
ChrisSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
No hurry, just wondering if you needed a test yet.
Dwight
- Herm Albright
Which ffdshow version for avchd encoding is best
By kukkamies in forum Video ConversionReplies: 3Last Post: 27th Jun 2011, 21:29 -
Not Sure if the Pro Version will fix this problem.
By Wakewatcher in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 16th Jan 2011, 13:34 -
handbrake 0.9.4 version number problem
By drumtrucker in forum Video ConversionReplies: 5Last Post: 26th Nov 2009, 10:23 -
BD Rebuilder new version problem
By fazza8 in forum Blu-ray RippingReplies: 5Last Post: 20th Aug 2009, 07:36 -
Crop without Re-Encoding - version 0.0.9x r2 - Several questions?
By llee782 in forum ffmpegX general discussionReplies: 6Last Post: 1st Jun 2007, 01:39
