Hi all,
Sorry if this has been answered before a quick search did not show me a solution.
I have a single vob file made with ifoedit, however the mpeg file is made up of two Vobid's.
When I load the vob file into Vegas it only shows the first Vobid. Is there a quick way of correcting
the file so Vegas can see it as complete. I could render it of course but is there a quicker way?
Thanks in advance..
VOB2MPG, then load the mpeg into Vegas ?
Why are you using a VOB in Vegas anyway ? Vegas VOB support is designed basically to support those stupid DVD video cameras, which generally have simple VOB structures. Added to that, Vegas will force you to re-render all your footage.
At this point you have the wrong source and the wrong editor. Have you considered using a dedicated mpeg editor, such as VideoRedo or Womble Mpeg Wizard, which are built from the gorund up to edit VOBS and mpegs without needless re-encoding ?Read my blog here.
Once again GunSlinger, I must thank you for passing on your knowledge. Vob2MPG worked perfectly.
Thanks to the author(s) for "their" hard work with a great application.
I am using Vegas 6. I could never get raw dvd compliant mpeg files to load with Vegas.
However problem solved now. I like to do a back up of the kids dvds for the grand kids.
Edit out the credits etc and role several short movies in increments. Keeps them amused for hours when the weather is not the best.
Regards...
Vegas image issues
By SKU in forum EditingReplies: 0Last Post: 29th Jan 2012, 18:13 -
Frame issues with Vegas 10 pro
By Jon.G in forum Video ConversionReplies: 16Last Post: 3rd Aug 2011, 17:24 -
Sony Vegas 8 issues
By sapph13 in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 15:27 -
Sony vegas issues?
By islandstyle in forum Newbie / General discussionsReplies: 1Last Post: 2nd Apr 2009, 02:38 -
Memory issues with Sony Vegas
By mouseclubhouse in forum EditingReplies: 0Last Post: 4th Aug 2008, 01:10
