http://www.pcworld.com/article/id,131168-page,1/article.html#
I always knew it. I've lost four harddrives in the past six years. Over this time I've owned a total of 9. The oldest working drive is 3.5-years and the youngest is a couple of months.Your hard drive may not be as reliable as manufacturers would like you to think. Recent studies by researchers at Carnegie Mellon and Google suggest that vendor Mean Time To Failure (MTTF) ratings for hard drives are a bit misleading.
Interesting report, but I don't get this part:
Surprisingly, Google's study found no correlation between drive failure and elevated heat and activity levels. The largest percentage of failures occurred on drives operating within a mild 77-to-88-degree range. However, desktop PCs typically operate at temperatures well over the maximum of 125 degrees reported in the Google study, so the findings do not support running hard drives without adequate airflow to cool them.
Now, if the largest percentage of failures occurred on drives operating within a certain (relatively cool) temperature range, and desktop PC's typically operate at temperatures well over the maximum of 125 degrees reported ... seems to me this is saying that cooling the drive makes no real difference. Yet the findings "do not support running hard drives without adequate airflow to cool them."
What findings?! They've got desktop PCs you can fry an egg on but the largest percentage of failed drives is coming from the cooler machines!
They're simply saying Google's data can't be extrapolated to temperatures found in typical desktop computers. Since all Google's drives run under 125 degrees it's always possible, for example, that every drive fails at 130 degrees. Google would never have found this.
I just had my big HDD change it's label to FAT16 and XP didn't recognize it. I then read it happens "occassionally" and thought wtf? Turns out I had completely filled it up within a few mb and it evidently needed more space to operate. After removing some files, I immediately backed it up with datadiscs because I can't trust HDD's anymore.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Repeated Lacie Drive Failures!
By Deane Johnson in forum ComputerReplies: 1Last Post: 9th Nov 2007, 10:32
