Hi, I want to play some DivX files on my Pioneer DV393S DVD player and have been able to get them to play on CD-R discs but was wondering if and how I can play them if I burn several of them onto a DVD-R disc and then finalise it. I have such a disc with a few files on it (finalised) but it won't play in the player. Is there something I need to do differently?
Thanks.
If your DVD player supports Divx, it will say so in either the manual or on the player itself. If your player supports Divx, normally just burning the files onto CD-R or DVD-R as data files is enough. Note that Divx support is NOT a firmware issue. The player must be manufactured with a special chip designed to decode Divx. No chip - no Divx support. Even on DVD players that support Divx, the following Divx options can be problematic:
1) GMC with warp points greater than 1
2) QPel (Quarter pixel)
3) Packed bitstream
4) Files larger than 2 GB
5) Bit rates higher than 2000 Kbps and DTS or AC3 audio
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
