Hello,
After quite a bit of searching I finally stumbled across a HOWTO on this site about splitting AVIs with VBR audio. I had been trying to do it with Virtualdub before (like I've always used in the past) but it errors because of the audio. Now that I've found a program that can split these types of files, however, I can't seem to find one that can join them. Are there any freeware tools that can join 2 VBR AVIs?
Thanks,
Nic
If you want to do anything to a VBR audio AVI, the first thing to do would be to replace the VBR audio with a CBR audio. things will be much easier after that relatively simple process.
/Mats -
VirtualDubMod has the same problem as VDub with the VBR audio. AVIDemux worked great though, thanks guys.
Nic
Join 2 AVIs
By phunkidude in forum MacReplies: 2Last Post: 23rd Dec 2010, 14:28 -
How do I join avis of different dimensions together? Or add borders?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 24th Jul 2010, 18:19 -
Join two avis... the 2nd has 3ms audio delay? how fix that?
By CactusMan in forum Newbie / General discussionsReplies: 4Last Post: 21st Mar 2010, 01:59 -
How do i join 2 AVIs with different resolutions?
By chocolate_brownie in forum EditingReplies: 7Last Post: 31st Jul 2007, 12:37 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 10:06
