Hi folks
sorry probably a straightforward question and I have done a quick search around the sites.
Each week I am provided with an authored (I assume) DVD of a sporting game and I need to analyse the game and 'cut out' highlights and create either another DVD, or store on my hard drive to show to the players at a later point.
What would be the best software package to do this? I need to watch the DVD and cut small segments every few minutes to put togther a package.
Any assistance would be really appreciated
MPEGStream Clip is good for cutting out segments and rejoinging segs you can export elementary streams for dvd authoring or straight mpegs depending on what authoring system you using.
TMpgenc DVD AUthor, select add dvd video and choose the video_ts on the old dvd, use the built in editor, make a new dvd. Done.
And please read our guides: https://www.videohelp.com/guides.php?guideid=638&howtoselect=5;18#638 -
Try Mpeg Video Wizard DVD. You can import DVD, cut and join with transition, if you wish, right there. Export file or make new DVD.
hi thanks again
what i found with TMPgenc is that it is almost perfect but i can cut selected information out that removes it from the file which I imagine would be great for removing unwanted information such as ads etc - however I want to keep what i cut as a separate clip and then join them together through a movie maker function.
As an example while watching the footage I want to grab a goal for example and then maybe a kick and then maybe another goal etc and then later group them and join them - so rather than removing the clips I want to retain them.
Does this make sense?
Any suggestions on software would be appreciated - maybe Mpeg Video Wizard -
You can do what you want in TMPGEnc Xpress (If that is what you have) by cutting sections only, leaving what you want and than exporting. It will be DVD compliant file not DVD. You will need authoring software to make DVD.
MPEG Video Wizard DVD will do. You can cut, join and export DVD with menu and burn.
So will TMPGEnc DVD Author.
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 22:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 22:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34
