I bought a Pioneer DVR-111D to better handle -R media.
I had a stack of -R media rejected by my Sony/Lite-On DRU-710A.
So my next writer was a Pioneer 111D/710. Then I bough 50packs of Verbatim -R and +R.
The 111D did burn most of the old -R media but "goes walkabout" at times. The strange thing is when it refuses -R Verbatim media it often burns with the +R Verbatims.
Do I have a faulty writer? Again? This is a replacement.
Results 1 to 11 of 11
Judging by my own experience with a few DVR-111Ds, I would say "Yes", either that or there is something wrong with your hardware set-up. Maybe you are not in PIO mode or are multi-tasking while burning?????
-Brett -
edDV what firmware are you using on your replacement 111D drive? Have you tried using the latest firmware? You could try a different brand of DVD-R since there have been reports of bad batches of VERBATIM dvd media.
Firmware is v1.23 dated 11 May, 2006
Connection is Ultra DMA Mode 5
Media was Verbatim -R 16x
All +R media has worked so far.
I see that a new firmware version is out (v 1.29)
I'll give it a shot.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I believe there's a 1.29 firmware update at http://www.pioneer.eu/eur/content/support/support/software.html, and you might try updating firmware to see if it helps.
You can always use the Buffalo 8.29INT firmware to auto-bitset +Rs to -ROM and forget about -Rs altogether.
http://tdb.rpc1.org/#DVR111D
(PS. You need to download+flash using the Buffalo 8.19INT BEFORE flashing to 8.29.) -
True but maybe the OP preferred DVD-R media.Originally Posted by obs
I updated the firmware. No -R Verbatim coasters yet.
Hey, come on! The dude bought both types (+/-)
Anyways, he should use the Buffalo firmware anyways. No reason not to. -
Some would prefer to use official PIONEER firmware for their drives because using the Buffalo firmware which is considered hacked/3rd party firmware will void the PIONEER warranty.Originally Posted by obs
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
What is the best DL media for Pioneer 1810 and DVR-710 drives ?
By MacPCConsultants in forum MediaReplies: 9Last Post: 2nd Dec 2007, 14:37 -
How is RiDATA DVD-R for Pioneer DVR-111D
By Mickey79 in forum MediaReplies: 20Last Post: 9th Nov 2007, 12:06 -
Pioneer DVR-710 Question
By hollywoodfussell in forum DVD & Blu-ray WritersReplies: 12Last Post: 20th Aug 2007, 13:25
