I'm looking for a good authoring software package. I want to be able to easily and flexibly create custom menus. I have looked at a few packages and find them to be too constrained and limiting. I suppose to make it easy to use, these programs are also less flexible. I am looking to create a two level menu. The top level offers the choices - Play or Menu. If "Menu" is selected, a second level menu is brought up with 24 graphic buttons that are images of a charter based language. I want to be able to insert and place each image and then easily set a chapter point and link it to each respective image.
An example of the frustration that I am having is illustrated with Ulead Video Studio 10 Plus. It's easy to set chapter points and link it to an image - their image which is just a frame grab of the first frame at the chapter point. You can't change the image to one you want to use.
The thing that I am looking to do is not some unusual exotic requirement. I want to be able to place objects that are menu "buttons" (even if they don't look like buttons) and link these to chapter points that I set. Should be simple -----. Any suggestions?
DVD-Lab can easily do this, even if it won't do the menu gfx for you
/Mats
Need good BD Authoring software
By faramith in forum Authoring (Blu-ray)Replies: 7Last Post: 13th Sep 2010, 22:17 -
Which authoring software has good motion wedding menus?
By sterankin in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2010, 05:21 -
Looking for a good authoring software that support using MP4 files to DVD
By LegendaryGamer in forum Authoring (DVD)Replies: 4Last Post: 10th Mar 2010, 17:04 -
Is this computer good for Editing/Authoring?
By sdsumike619 in forum ComputerReplies: 6Last Post: 20th Nov 2008, 20:13 -
What is a good authoring tool?
By breeze9 in forum Authoring (DVD)Replies: 1Last Post: 26th Jan 2008, 01:17
