I am building up a DVD describing the places I visited during a voyage. I need the camera to look at a map from high above and zoom in to the location visited. The location is either a city or an island. For this purpose I can find the maps from internet. My question is what is the best way to do this process? Which software should I use? In what format should the video asset be? Please advise. Thanks in advance.
I would use Google Earth, http://earth.google.com/ , and try capture the zooming using a desktop capture tool like Camstudio or Fraps. See http://googlesystem.blogspot.com/2006/09/record-videos-in-google-earth.html
MS Photo Story 3 has an effect where you easily can set start rectangle and end rectangle for a still, and create a zoom effect. You could start with a big rectangle in the upper left corner, and end with a small rectangle in the lower right. The video would then start "high" above the upper left part of the map, then zoom in to a location inthe lower right. Of course start and end rectangles can be anywhere in any size. Only limitation is that the movement is linear.
/Mats -
It's a pretty big download, but NASA's World Wind can zoom into and out of any place on the earth, moon, mars and even jupiter. You can save the sequence as a series of stills or a movie.
Thanks for the responses. Using Fraps for screen capture and video recording is quite handy. The Google Earth and NASA site also offer valuable tools. I also found another solution. With Proshowgold from Photodex <www.photodex.com> I used the zoom and pan function on a high resolution map. Proshowgold can render slide show as an MPEG2 file. I then merged the resulting file with my video files using TMPGenc. The result is quite good. I hope this discussion will help users dealing with similar problems.
Limiting the amount of zooming After Effects is doing during stabilization?
By kingmustard123 in forum EditingReplies: 3Last Post: 3rd Jul 2011, 10:12 -
Zooming to adjust Chroma
By Tafflad in forum EditingReplies: 4Last Post: 20th May 2010, 06:04 -
Lines in middle of video when panning or zooming in/out
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 11th Jun 2008, 17:31 -
zooming on a screen area
By brushuk in forum EditingReplies: 1Last Post: 29th Apr 2008, 06:17 -
How to stop convertxtodvd from zooming in
By andre477 in forum Video ConversionReplies: 40Last Post: 7th Jun 2007, 09:16
