I have several mpg files that play ok but -
If you play them in Winamp you can't jump forward or backwards in the file. As soon as you touch the position bar the movie restarts.
If you play them in Windows Media Player then you can jump around in the file ok
I have tried running VCDGear in repair mode in case there was a file fault, but none was found.
I think I understand the "very" basics of the coding, and can't see why you can't jump between master frames. There is obviously more to this that I don't understand
Can someone explain please and is there a way to get Winamp to do this. It does everything else I have ever wanted it to do. I really don't want to use WMP
What is the source of these files? Some sort of capture, perhaps?
There are lots of little items with MPG that can cause this result, how you handle it depends on the source of the files.
If created on your PC, some simple steps like closed GOP or audio types may solve it. The real answer is to find a software that plays the files adequately. If the file won't play, it does not matter how much you like the program's interface.
If the files were created elsewhere, and this source will vary, there really is no answer as what works for one may not work for another.
Try VLC, WinDVD, Ulead movie player. There are many other players.
Just re-checked you specified Winamp failed and WMP worked. What that means is that Winamp failed and WMP worked. The file is not the problem. I had similar issues with Winamp. Abandoned the prog within 5 minutes to find something which worked. Have chosen WinDVD simply because FF is easily accessible with a wireless keyboard.
[help] Jump to specific url after playing wmv video file
By techtonik in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2011, 07:23 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
WMV file cannot fast-forward
By joelson in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2008, 12:46 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 21:43 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
