Hi all:
Tried some programs to record from internet, but the result is very poor.
Too much "BASS" and somehow distorted sound , in spite of having recorded as low as possible.
My tests where made with Audacity and super mp3 recorder.
Am i doing something wrong or there's not a perfect tool for this ??
Results 1 to 17 of 17
Your sound card will have different devices that you can record from, described in different ways. One will be called wav, another - on some cards at least - is called 'What you Hear'. Which one of these did you use ?
From what you have described, you have recorded with FooBar and are simply using Audacity and Supermp3 to encode ? Is this correct ?
What do the files sound like before compression ?Read my blog here.
First I want to thank you for yr patince.
Now, as you said I open radio streaming using foobar.
The sound is quite good.
About the sound card, well all I know is that on super mp3 I selected as recording device, my sound car through "sound max digital audio"- there are many options: mic, mono wayout, aux,phone,mixed wave-out, line-in)I used only line-in and mixed wave-out !!! I think i dont have "what you hear". -
Sorry i dont find stereo mix as an option !!
Where do i select that ?? -
Audacity uses the LAME MP3 libraries, which are generally well regarded. Unless you have added filters, you should be hearing what you recorded.
Double-click the speaker icon in the tray to open the mixer controls. Click Options->Properties to see the list of controls for playback. If you click on the radio button next to Recording you will see the recording controls listed. Tick the ones you want to see or set levels for.
The labels for these controls is set by your driver software, so you may not have the same names as you will find on another PC. For example, I don'r have a Stereo Mix option, but I do have Wav/MP3, and "What U hear" as Recording controls.Read my blog here.
guns1linger already took you the direct way but there is another through windows controlpanel (just pointed out in case you can't tick the radio button): go to 'sounds and audio devices', tab 'Audio', 'Recording' (just guessing because I don't have an english OS, but it's the second dropbox) click 'Volume' and you have the controls. If you don't see 'Stereomix' chose 'Options' and 'Properties', all available controls are there. I'm pretty sure you have 'Stereomix'.
Regards -
The is a tools section to your left. Plenty of software linked there. However I don't believe it will fix your problem. Audacity works fine, and when paired with LAME produces as good a quality MP3 as your will fine (not that that is a high recommendation - I think MP3 is a pretty average compression scheme, and you are compressing heavily compressed audio). That it affects two separate programs strongly suggests that this issue is a bigger one.
Read my blog here.
Ok Guys.
Today I'm too short in time.
I will try yr sugestions as soon as possible and will let you know the results. -
Ok I managed to make a decent recording.
Good enough for my purposes.
thanks.
Ripping Video Stream from Internet Connected / Networked BluRay Player...
By salinesky in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Jun 2011, 12:58 -
Stream internet video to tv
By zinc in forum Video Streaming DownloadingReplies: 4Last Post: 24th Sep 2010, 08:57 -
re-streaming a TS Stream from Internet into my Lan
By vel2000 in forum Video Streaming DownloadingReplies: 0Last Post: 30th Jul 2010, 03:37 -
It's easy to record a stream but...
By uglijimus in forum Video Streaming DownloadingReplies: 0Last Post: 24th Nov 2008, 15:12 -
75 year old downloads full movie in 2 seconds - internet speed record
By Heff in forum Latest Video NewsReplies: 14Last Post: 22nd Jul 2007, 00:33
