Hey all, hoping to find some answers here as its getting quite frustrating now..
So I shot some footage with a JVC GY-HD101 camera and captured it into Premiere. Now, one weird thing I noticed was that the framerate of my footage is 23.98. I thought I had set it up correctly since I live in Sweden and we have PAL system here..but seems not
Ok, but 23.98fps means it's NTSC correct? The framesize however is 1280x720 which I presume means it's 720p HD?
So now, I guess I want to convert this into PAL, and I have tried some various guides on how to do this, but with no bigger luck yet. To me it seems that the framesize and the framerate are like ying and yang. For creating a PAL DVD, 1280x720 is perfectly fine (since it doesnt lose its 16:9 look if I convert it to 720x576) - but the framerate is off since its NTSC. My DVD-building programs won't even let me import something that isn't 25fps.
But if I wanted to create a NTSC DVD for some reason, the framerate is fine, but the framesize gets all wrong then as NTSC DVD wants 720x480 ?
So basically, what can I do to save this footage and create a PAL DVD with correct settings? I tried to create a mpeg-2 with 720x576 and force it to use 25fps using that Adobe Media Encoder in Premiere (Also used widescreen 16:9 - 1.422) - and while the material looked "ok", it seemed a bit off since it's adding an extra frame I guess?
Help is so much appreciated, even if it's just answering some of my newbie questions mentioned above.
Results 1 to 1 of 1
Edit out material from dvd's/Need advice please
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2010, 19:15 -
What the heck is Unreferenced Material ? ? ?
By nhbfan12345 in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2008, 17:01 -
6.5gig of HD material on a DL
By luketheduke in forum Newbie / General discussionsReplies: 2Last Post: 16th Jan 2008, 16:53 -
Material with interference problems needed
By sylvanez in forum RestorationReplies: 2Last Post: 28th Oct 2007, 15:21 -
How to access unreferenced material
By attmay in forum MacReplies: 2Last Post: 6th Jun 2007, 10:30
