I've just borrowed some VCDs from China and was astounded to find they claim to have AC-3 or Dolby 5:1 sound. Some really do have two audio streams, Cantonese on the left channel and chinese on the right.
While I believe the claims of AC-3 are just over-enthusiasm by the Vendors, I would really like to know HOW IS IT POSSIBLE TO CREATE TWO LANGUAGE STREAMS ON A VCD?
Thanks for any help that can be offered.
Hsinchiang
Carry on Ripping
Right audio channel one language and the left channel another... Just mono sound then though... You probably need to use a sound editor and cut and paste into the different channels...
Magnus Jensen
A.K.A Geezus -
Most of this should be reasonably self-evident...
Rip your movie then separate rip the two audio streams...
Convert the two soundtracks to uncompressed PCM WAV mono.
Use an audio editor like CoolEdit to copy one language to the left channel and one to the right channel.
Save.
Encode this dual language wav file to MP2 audio (as used on VCDs) at 224 kbit/s.
Multiplex the audio with the video.
Regards.Michael Tam
w: Morsels of Evidence
i have a video that has 2 audio streams..what does that mean?
By vincy in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2012, 05:45 -
MP4 with 2 Audio Streams
By kohkae in forum Video ConversionReplies: 3Last Post: 26th Nov 2008, 11:47 -
DVD Audio Streams
By jeh in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2008, 15:23 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00 -
Multiplex with two audio streams
By heretic754 in forum AudioReplies: 2Last Post: 1st Jun 2007, 23:44
