Results 1 to 15 of 15
    Jun 2006
    I just received email from pinnacle about a new version of studio. I wonder if it will support MPEG edit with smart rrendering.
    http://www.pinnaclesys.com/PublicSite/us/Home/
  2. I wonder how many patches it will take to get a halfway workable product to the consumer and how long will they take? That is, taking into consideration that they can even get it to work. I haven't visited the forum over there in a while. Did they ever get version 10 fixed?
    Mark
    Jun 2006
    I used Studio 9 and never upgrated to V10 because of all complaints I read on line and heard from friends.
  4. I bought Studio9+ - Whata mistaka to maka! Absolute rubbish! I never did get it to finish even a simple project. Went back to Ulead VS9/10 and TMPGenc DVD Author and all's been hunky-dory since.
    Aug 2002
    South Florida
    Stay with Ulead VS 10!
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    im surprised avid has not shut down the consumer software div. .
    it is not why they bought them anyway
  7. Although it is a vista product, the manual is still written for XP. There were no background music files in my software. Pinnacle support never replied (8 days ago). Vista kind of sucks too. Too make it look new, Microsoft simply re-arranged alot of things, just adding confusion.
    Sep 2007
    @ Tom81
    The interface for Studio 11 is the same for XP and Vista so the manual does not mention any OS. Basically you do the same thing to access a feature in Studio 11 regardless if it is XP or Vista. There may be an FAQ in an appendix that may mention XP but Vista is pretty similar and you can find an updated FAQ on our web site most likely.
    To access background music, go to the audio toolbox and select the background music icon (looks like a musical note). You can add background music this way. If you need help, go to chapter 11 in the manual, specifically page 173 which mentions Scorefitter which is the Pinnacle background music generator.
    If you had a previous version of Studio that had SmartSound and you would like to use that, then go to this FAQ on how to use SmartSound in Studio 11.
    http://pinnacle.custhelp.com/cgi-bin/pinnacle.cfg/php/enduser/std_adp.php?&p_lva=&p_faqid=15605
    Hope this helps,
    Rich Edgley
    Technical Support
    Pinnacle Systems
    Aug 2002
    South Florida
    Stay with VS 10, but if you want to modify the video, go to VS11. They have white balance correction, color corection and some new good filters.
    If I listen to all those complaints about any product, I would never be able to do a thing. What does not work for one, may work well for another. Some machines may be ladened with so much junk that they cannot get off the ground. It's an empirical world-especially with computers. So, take the plunge.
  10. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    AVID is a very arrogant company by consumer standards. Some upper strategerist wanted consumer exposure but the internal AVID geeks wouldn't lie to consumers ... so they bought Pinnacle! Problem solved?
  11. Originally Posted by edDV
    Yeah, the "upper strategerist" was probaly promoted for the debacle. And the AVID geeks are now left alone.
  12. Member edDV's Avatar
    Mar 2004
    AVID was trapped at the high end with little growth prospect. Wall street demands growth. Hence the "strategery".
  13. Originally Posted by edDV
    Most likely why their CEO left (fired).
    The problem is Pinnacle support is very bad, and their quality control is even worse.
  14. Member ejai's Avatar
    Jun 2001
    New York USA
    I own Pinnacle Studio 11 and it works as advertised. I only have one gripe and that is the mpeg 2 encoding isn't up to par. Ulead's Moviefactory and Sony Vegas do a much better job of encoding.
    One last thing is that I am not very happy with paying extra for 3rd party transitional effects. Other than that I think the product is stable and adequate for most dvd authoring jobs.
    Do unto others....with a vengeance!
  15. I think the clue is probably in the "3rd party" bit of "3rd party transitional effects" It's just a way to try and keep the price down and not have users moan about having to pay for extras that they never use.
