I have a image of the problem I am getting below (choose save as and open please, geocities wont let you view it in that format).
http://geocities.com/maso2k1/example.jpg
It occurs randomly throughout the capture and sometimes deinterlacing will reduce the occurances but never completly removes it. I normally capture at 704x576 but dont find I get the problem as much if I capture at 352x288, though obviously the final output is not as good.
This is the hardware I am using;
Athlon 1.2Ghz
Asus A7A266 Motherboard (ALi Chipset)
512mb DDR
WD 40gb ATA100 Hard Disk (DMA Enabled)
Hauppage WinTV Primio PCI
Soundblaster Live
The hauppauge card shares and IRQ with IRQ Steering but nothing else. I am running Win98SE and XP Home, but cant capture at 704x576 in XP due to WDM drivers so cant see if problem occurs there as well.
Thanks for any help guys (and sorry for such a long post!) :D
I have been having the same problem as MeSo...I have tried messing with the Disk I/O (in VDub), using different codecs, everything! PLEASE someone help MeSO and me out! Thanks in advance.
I think I might have solved it.....
1) Moved WinTV card to PCI Slot 1
2) Set PCI Latency to 10
3) Installed latest driver off www.hauppauge.co.uk
4) Installed ALi chipset updates
5) Started using YUY2 instead of RGB24 as RGB24 seemed to cause some kind of interference (I suspect related to PCI bus)
This seems to be working at the moment though I would ideally like to use RGB24, something for me to keep working on. Hope this might help some people out.
MeSo
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
