I have to create a slideshow for a party. I've done it before but I just played music separately while pictures flashed on the screen, and it was a smaller screen. I want the pictures to be clear on a big screen. I don't have the dimensions of the screen but picture a wedding with approximately 300 guests.
I have a program that I am using (Wondershare DVD slideshow builder). Should I choose DVD or SVCD for the output? When I choose DVD, it asks me for the layout dimensions (height/width). What should those be?
I scanned 4x6 photos @ 300 dpi. I plan to add music, transitions, and text onto the photos.
Any suggestions for a different program to accomplish this task?
I appreciate any assistance anyone can offer. Thanks.
MS Photo Story 3 - export at highest possible quality, encode to DVD specs mpg, author as DVD.
MS Movie Maker is also capable of creating what you want - Export as DV, then encode to DVD specs mpg, author as DVD.
Or ProShow or other slide show app.
/Mats -
DVD will give you higher resolution than SVCD, and allows for a higher bitrate for better quality. If you decide to go down the PhotoStory route, make sure you get Papa John's templates for DVD output. The quality difference is worth it.
Wondershare can't be much of a DVD product if it doesn't know the dimensions of DVD compliant output.
Of course, if you aren't limited to playback via DVD then you can encode to much higher resolutions.Read my blog here.
How do I create a slideshow of photos and short movies?
By wreckage in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2011, 04:44 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
create slideshow
By shashgo in forum Newbie / General discussionsReplies: 27Last Post: 14th Aug 2008, 12:13 -
Want to Create Slideshow DVD to show on My HDTV
By 1deciple in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2008, 16:54 -
App to create slideshow as video???
By vulcan4d in forum Newbie / General discussionsReplies: 5Last Post: 20th Jan 2008, 21:56
