Hi guys, can anyone help me importing the subtitles from the DVD, I'm using the following programs for ripping:
SmartRipper
DVD2AVI
TMPGEnc
VCDEasy
if not possible doing it with these ones, pls recommend any other. :) Thanx a lot
unfortunately you can't
there is some other software to use, like virtualdub, to have your work done. -
it all depends if you want subtitles endcoded "on" the picture or if you want selectable ones.
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
VCD subtitles must be hard-encoded.
SVCD subtitles can be selectable but these are not well supported on many stand-alone players.
I strongly suggest that you have a look at the guides at http://www.doom9.net as they have it all covered.
IMHO, for VCD subtitles, FlaskMPEG is a good option...
Regards.Michael Tam
w: Morsels of Evidence -
Originally Posted by clickit_
Video Import Help with VirtualDubMod - Subtitles Workshop!
By rp0094 in forum Video ConversionReplies: 13Last Post: 10th Dec 2009, 18:32 -
Exctract Subtitles from .vob -> Import into Sony Vegas or DVD-Architect
By mltwitz in forum SubtitleReplies: 4Last Post: 4th Oct 2009, 02:16 -
import error
By mypumpkins in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2008, 07:40 -
Import subtitles from a commercial DVD into Adobe Premiere Elements?
By haggis999 in forum Newbie / General discussionsReplies: 44Last Post: 11th Apr 2008, 19:44 -
DV import help
By VirtualDoobMon in forum MacReplies: 3Last Post: 4th Mar 2008, 01:34
