Hi, i hope someone can help me,
I organize conferences and after them we will like to give around 100 dvds copies of it.
I know we need a camera conected to tape de conference and after that need a duplicator
or a tower, we will like to hand them right after it no more than 20 min later
does anyone know the best duplicator or tower?
cause there are duplicators but very expensive and it will duplicate 100 dvds in 1 hrs
should we get a tower of 20? o more? i have being looking and looking and havent found something that will fill my needs and will appriciate some guide and help
thanks!
Results 1 to 10 of 10
From cam to 100 authored DVDs in < 20 minutes? No way, I'd say.
Possibly if you recorded on a DVD cam, and just duplicated the raw footage on a high speed high capacity duplicator(s). Can't these duplicators be rented?
/Mats -
Well i prefer to buy it.. im in mexico and i ve done my research and i do bealive that no one has this equipments...
so i dont mind buying a duplicator or a tower
i was thinking maybe a tower for 20 dvds and its seems on my research it takes 7 min for those 20 dvds... so in 30 min i would have my 100 dvds.. but i want to know if that is my best option and that if im rght! thanks for you help -
There is no benefit from having all your burners in just one BIG tower. Buy several smaller towers - 1 to 7 for example. You can determine the number of towers by calculating the burn speed and the number you need to burn in a given amount of time. Another benefit of having several smaller towers is if one fails, you still can use the others. If you only have one and it fails - you're dead!
You might take a look here: http://www.supermediastore.com/dvd-duplicator-tower-pioneer-16x-dvd-cd-duplicators.html There are duplicator towers for 20 DVD's up to 70 near the bottom of the page.
But getting them to DVD format in under 20 minutes... not likely, unless you just want the raw, unreferenced video.
It would be better to properly edit the video (you don't mention the length of these conferences, but if they are over 2-2.5 hours, then post processing is almost a necessity), and cut out the dead spaces. Then add the chapter marks (with a corresponding chapter menu) and a nice main menu.
Better to just use the mail system to get the finished product to the participants - or, have them wait around for two days while the DVD is produced.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Comments about the time required to properly edit and author a DVD are correct. However, there is a substantial market for live DVD's and CD's that are sold and delivered at performances. The reason for this is that the numbers sold are far higher when "instant" delivery is possible. Those that do this usually record directly to a DVD recorder and do zero editing. They copy the discs "as is" right off the DVD recorder. Often times they have preprinted blank discs ready to go as soon as they come off the duplicators. This is becoming more popular with bands for example.
Thanks all foor you help
that is exactly what i want.. to have the dvds pre printed.. so when the conference ends.. i just start duplicating what i had recorded in a dvd with out editing... and have them ready asap
so buying several towers is a good option right? -
Multiple towers is the safest way to go. You can use as many as you need to do the job in the time frame that you need. But you also have the security of having more than one. In the event one fails, you still have the others to use.Originally Posted by marmas
Towers realy are expensive.
Cheaper option is to by a PC with a lot of PCI slots and put like 6 IDE controllers of four drives each in it. Controllers of four drives are usually cheap. I curently burn DVDs on a PC which has four DVD burners connected to system IDE controller plus 8 DVD burners connected to 2 cheap PCI IDE controllers (cost like 2x15$). PC has 3GHz PIV wich is employed for around 20% when burning. The system and burn data resides on two SATA HDs of 400Gb and 500Gb.
dsc00156.jpgCann't tell it's possible don't tell anything.
Shortest possible movie container virtualdub
By cyberlion in forum EditingReplies: 30Last Post: 18th Aug 2010, 06:55 -
HELP: DVD-to-Divx 100% quality, time-splitting... for youtube
By andwan0 in forum DVD RippingReplies: 7Last Post: 9th Sep 2009, 06:50 -
Stop VLC from using 100% cpu time
By rock.freak667 in forum ComputerReplies: 13Last Post: 4th Apr 2008, 21:56 -
Is this the shortest path or can I combine steps?
By chrishallowell in forum Newbie / General discussionsReplies: 4Last Post: 3rd Nov 2007, 13:37 -
shortest way to encode 5.5 hrs of avi's using tda3
By cduval04 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2007, 13:38
