Awesome piece of software.
There does seem to be a problem with PE mis-reading the size of a VIDEO_TS folder when created by Nero Recode. The actual size of the folder is, of course, around 4.3 G, but usually PgcEdit comes back with a higher #, one too high to burn to a single layer disc.
Anyone know what might be causing this??
Do you have other files at the same directory level as VIDEO_TS or in other subdirectories at the same level as your VIDEO_TS folder? If so, PgcEdit will read everything at the same directory level as being part of the DVD and will give you too large a size as it's trying to create a DVD with everything. For example, if you have a directory called MY_VIDS and underneath that you have the VIDEO_TS directory that holds 4.3 GB of video and you also have in the MY_VIDS directory miscellaneous other video files that equal 1 GB in size, PgcEdit will sum up the VIDEO_TS directory and everything at the same directory level and give you 5.3 GB of size needed for the ISO. Move or remove any files at the same directory level as VIDEO_TS and it will report the correct size.
PGCEdit question
By gbabione in forum EditingReplies: 14Last Post: 27th Feb 2012, 22:21 -
PGCEdit Question
By billynews in forum DVD RippingReplies: 5Last Post: 17th Oct 2011, 05:02 -
adding a button with pgcedit question
By spiritgumm in forum Authoring (DVD)Replies: 1Last Post: 4th Oct 2010, 05:41 -
DVD-9 Layer Break Question (PGCedit)
By sdsumike619 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jan 2010, 19:19 -
PGCEdit question: setting menu button highlight positions for letterbox
By Alex_ander in forum Authoring (DVD)Replies: 10Last Post: 5th Jun 2008, 12:55
