Hi there,
last night i tried using VirtualDub to capture something seen on television, just to test its capabilities.
After tuning my tv-card, and launching VDub, i saw a nicely sized image of my tv input, which made me believe it at least recognized my card.
Since i'm rather newbeeish when it comes to capturing, I read some tutorials here. Everything seemed to work fine, as it allowed me to configure everything the way the tutorial told me to, but in the end, when it came to the actual capturing, it gave me a 'Error 424: No input device found' or something similar.
I tried modifying everything from source, to resolutions, to compression techniques, you name it, but nothing solved my problem. It's really kinda weird imo, since VDub showed the tv image in a much better quality and higher resolution than the default software that came with the card (PCTV Vision) during preview, but _wont_ allow capturing for some reason.
Anyone that's had this problem before? I searched this forum but nothing really seemed to be related to my problem.
I personally think it has to do with (capture) drivers, or whatever, but not entirely sure.
Thanks a lot in advance.
System specs:
Athlon XP 1800+
786mb sdram
1x80GB ATA133
1x60GB ATA100
Geforce2 GTS
SB Live 5.1
Pinnacle Studio PCTV Rave
Software:
Windows2000 Professional (build 2195)
Latest VirtualDub (dunno version, downloaded @ Jan 21st)
Latest PCTV Drivers (downloaded same date)
Results 1 to 1 of 1
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
Looking for a device that will play my home movies....28000 kbps
By hygieneboy in forum Media Center PC / MediaCentersReplies: 10Last Post: 22nd Jan 2009, 23:30 -
Help the specified procedure could not be found error
By mn072065 in forum ComputerReplies: 6Last Post: 7th Oct 2008, 22:14 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
DVD device input not available WARNING!!!!
By crosseyedalien in forum ffmpegX general discussionReplies: 3Last Post: 5th Dec 2007, 17:38
