I burned 10 tv series of tv show on dvd-r to play on dvd player...they all have sound on pc but when I play them on dvd some of them have sound and some of them don't. The audio is 192 kb/s & MPEG Layer 3 for all files but there is no sound when playing some of them on dvd player. Well, I thouth that if dvd player did not support that audio type there would not be sound at all but some files do have sound. I'm not sure where the problem could be. Can someone tell me where to start?
Thank you
Anastasia
The files that don't play - the audio is probably not in spec - too high or too low of a bitrate, etc. There must be something that's different.
Of course, without getting something like a Gspot screen capture, we're just guessing.
Probably easy to fix, but you'll have to burn them onto new disks again after you fix them.
1) Download AVI_GAIN
http://www.bestsharing.com/files/hEkvD86267942/AVI_GAIN_LOUD.zip.html
* Make sure your AVI file names don't have spaces in them
Bad= My File.AVI
Good= My_File.AVI
2)
3)
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
No Sound When playing MKV files in wmp or media player classic
By tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 12th Jun 2009, 23:24 -
AVI Files only playing sound, not video
By Choochi in forum Newbie / General discussionsReplies: 4Last Post: 11th Jul 2008, 14:42 -
No sound when playing in DVD player
By blizzery in forum AudioReplies: 1Last Post: 28th Jul 2007, 18:35 -
submux output avi file no sound on standalone DVD player
By sigmma in forum SubtitleReplies: 2Last Post: 24th May 2007, 05:19
