Hi, I downloaded an avi video file that claimed to contain AAC audio (and WMV9 video). I wanted to convert it to a format playable on my PMP, so I tried to extract the AAC to re-encode to Ogg or MP3, but VirtualDubMod doesn't seem to be doing the trick. When I select the extract WAV option, the WAV file just seems broken. When I just let it demux, the aac file doesn't play back correctly. I tried converting the aac to other formats using dbpoweramp, but the resulting mp3 or ogg file is about 1/3 as long as it should be and plays back all muffled and at half speed.
I was wondering if anyone had any tips or guidelines, like another option or what I might be doing wrong. Thank you!
Download ffmpeg - http://www.paehl.com/open_source/?download=ffmpeg.zip
Download his small script (right-click to save).
avi2aac.cmd
Place your AVI, ffmpeg.exe, and avi2aac.cmd into the same folder.
Double click on avi2aac.cmd to run
Good luck -
Thank you, it worked perfectly!
Any clue as to why VirtualDubMod couldn't do it? Is it a well-known problem? -
Can't say for sure, probably because it is looking for a specific decoder installed on your system that it couldn't find...
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 22:59 -
Need help demuxing a M4V file
By FulciLives in forum Video ConversionReplies: 1Last Post: 8th Aug 2011, 02:18 -
Problem with demuxing .ts file
By iXed in forum DVB / IPTVReplies: 5Last Post: 8th Aug 2010, 10:14 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25 -
Demuxing a TS file
By carlmart in forum Video ConversionReplies: 17Last Post: 29th Jul 2009, 16:04
