Hi
I'm converting DivX so that it plays on my DVD player. I have tried the following resolutions at the moment and they all work.
352x288
352x240
480x480
480x576
I also tried 640x272 and that didn't work at all. Can anyone suggest other resolutions to try. The number of frames per second and bitrate don't seem to matter with the above resolutions. My DVD player happily copes with XVCD and XSVCD.
Please do not tell me about DVD resolutions like 720x576 etc. as I know these don't work either. Mini-DVD isn't supported for my Wharfedale M% 1.7 firmware.
-Darren![]()
Try D2: 352 X 576
It is a very good resolution: Compatible both with svcd and DVD on most DVD players -
if you want better results you need a better source. right click your divx file in windows explorer and look at the summary tab. if the video data rate is lower than 125 KB/s and your video frame size is less than 352x240 dont expect very good results. the best you can do is play with filters in the hopes of preserving some quality.
if your divx file just meets the specs i stated above expect moderate results. but there will still be macroblocking.
the best results i have gotten has been with 640x480 DivX with at least 125 KB/s of data converting down to 352x240 VCD.
Youtube HD Resolutions
By bseos in forum Video Streaming DownloadingReplies: 12Last Post: 14th Oct 2011, 11:50 -
Video Conversion: Variable Resolutions anyone?
By thyepoch in forum Video ConversionReplies: 1Last Post: 5th May 2010, 10:57 -
Screen Resolutions
By ranosb in forum Video ConversionReplies: 4Last Post: 25th Aug 2009, 03:04 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 13:13 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
