I wanna know If you know de hack for HTS3555/37??
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control up/down keys select the region number you'd like to use (select region 0 for region free) and press OK.
Power off and Enjoy -
yes i have Philips hts3555/37 and the hack worked just fine on mine and you might have to press number 0 to make it region free instead of scrolling down on the remote
