For the moment I´m testing the functions in DVDAuthorGui. For the test I use a 100 MB file with a duration of 159 seconds., which I have demuxed with ProjectX before loading into DVDAuthorGui. After the authoring the result is a 22MB/32 seconds file, the rest is simple missing. I use the latest version of DVDAuthorGui but have also tried an older version with no luck.
Results 1 to 9 of 9
if you could either post the log, or send it to me, I would be happy to examine the problem for you.
liquid_217@hotmail.com -
It opens in notepad after the authoring process finishes. Copy and paste that text here, or save it, and attach it to an email.
You can also find it in c:\Program Files\DVDAuthorGUI called
DVDAuthorGUIlog.txt -
I've used this program for almost as long as it's been out and I've only had problems with the previous release(I think it was 1010b). And that was fixed with the present release.
OK, here is the log file:
DVDAuthorGUI 1.011 - 3/8/2007
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File D:\ProjectX\8Mile.m2v looks like an MPEG Video stream.
INFO: [???] File D:\ProjectX\8Mile.mp2 looks like an MPEG Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (D:\ProjectX\8Mile.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 704
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 16:9 display
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 8146400 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: Audio stream c0 (D:\ProjectX\8Mile.mp2)
INFO: [???] MPEG AUDIO STREAM: c0
INFO: [???] Audio version : 1.0
INFO: [???] Layer : 2
INFO: [???] CRC checksums : no
INFO: [???] Bit rate : 32768 bytes/sec (256 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] Mode : 0 stereo
INFO: [???] Mode extension : 0
INFO: [???] Copyright bit : 1 copyright protected
INFO: [???] Original/Copy : 1 original
INFO: [???] Emphasis : 0 none
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 8582144
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [???] Scanned to end AU 3981
INFO: [???] STREAM e0 completed @ frame 3981.
INFO: [???] STREAM c0 completed @ frame 6635.
INFO: [???] Multiplex completion at SCR=14337609.
INFO: [???] Video e0: buf= 210924 frame=003981 sector=00048747
INFO: [???] Audio c0: buf= 256 frame=006635 sector=00002523
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 98368588 bytes
INFO: [???] Sequence headers: 332
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 3981
INFO: [???] No. Groups : 332
INFO: [???] No. I Frames : 332 avg. size 78806 bytes
INFO: [???] No. P Frames : 996 avg. size 28107 bytes
INFO: [???] No. B Frames : 2654 avg. size 16657 bytes
INFO: [???] Average bit-rate : 4940400 bits/sec
INFO: [???] Peak bit-rate : 8146800 bits/sec
INFO: [???] BUFFERING min 16 Buf max 139913
INFO: [???] AUDIO_STATISTICS: c0
INFO: [???] Audio stream length 5096448 bytes.
INFO: [???] Syncwords : 6636
INFO: [???] Frames : 6636 padded
INFO: [???] Frames : 0 unpadded
INFO: [???] BUFFERING min 15 Buf max 779
INFO: [???] MUX STATUS: no under-runs detected.
*preprocessing sup for title: 1 sub 1...
1 fil(er) kopieret.
00:00:02.13
00:02:32.60
Writing image files and spumux.tmp.
Writing palette.ycrcb and palette.rgb.
Renaming spumux.tmp to spumux.xml.
Output files reside in C:\Programmer\DVDAuthorGUI\sub1-1.d/
All done.
1 fil(er) kopieret.
*processing subtitles for title: 1 sub 1...
DVDAuthor:pumux, version 0.6.14.
Build options: gnugetopt iconv freetype
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=C
INFO: Converting filenames to US-ASCII
STAT: 0:00:02.130
INFO: PNG had 4 colors
INFO: Constructing blank hlt
INFO: Constructing blank sel
STAT: 0:00:06.034
INFO: Max_sub_size=3612
STAT: 0:00:09.654
STAT: 0:00:13.694
INFO: Max_sub_size=3724
STAT: 0:00:17.204
STAT: 0:00:32.654
INFO: Max_sub_size=4884
STAT: 0:00:38.484
erase "D:\ProjectX\test7\presub.mpg"
echo *authoring title(s).....
"C:\Programmer\DVDAuthorGUI\bin\dvdauthor.exe" -x "C:\Programmer\DVDAuthorGUI\config.xml"
DVDAuthor::dvdauthor, version 0.6.14.
INFO: Locale=C
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing D:\ProjectX\test7\title1.mpg...
STAT: VOBU 16 at 4MB, 1 PGCS
STAT: VOBU 32 at 9MB, 1 PGCS
STAT: VOBU 48 at 14MB, 1 PGCS
STAT: VOBU 64 at 20MB, 1 PGCS
INFO: Video pts = 0.184 .. 32.904
INFO: Audio[8] pts = 0.184 .. 32.632
INFO: Audio[32] pts = 2.314 .. 23.269
STAT: VOBU 69 at 22MB, 1 PGCS
INFO: Generating VTS with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: pal
INFO: Aspect ratio: 16:9
INFO: Resolution: 704x576
INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
STAT: fixing VOBU at 4MB (17/69, 23%)
STAT: fixing VOBU at 9MB (33/69, 46%)
STAT: fixing VOBU at 14MB (49/69, 69%)
STAT: fixing VOBU at 20MB (65/69, 92%)
STAT: fixed 69 VOBUS
INFO: dvdauthor creating table of contents
INFO: Scanning D:\ProjectX\test7/VIDEO_TS/VTS_01_0.IFO
erase "D:\ProjectX\test7\*.mpg"
echo *process complete
*process complete -
Try authoring without the subtitles. If it is the correct length after authoring, then the problem is with the subtitle muxing process. If it is still too small, I would point the finger at your m2v stream. Looking over the statistics from mplex, your m2v looks ok, but you might try running the m2v through restream, just to make sure.
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59 -
DVDAuthorGUI Problem...
By beckmen in forum Authoring (DVD)Replies: 12Last Post: 1st Jul 2010, 12:34 -
bug in DVDAuthorGUI with sup-files
By Pii in forum Authoring (DVD)Replies: 0Last Post: 18th Oct 2008, 05:58 -
DVDAuthorGUI: How do I write?
By videohalp in forum Authoring (DVD)Replies: 1Last Post: 8th Jul 2008, 20:29 -
DVDauthorGUI question
By AlecWest in forum Authoring (DVD)Replies: 2Last Post: 20th May 2008, 12:46
