I have friend with water damaged VHS-C tapes (some have mud all over the cassette shell) that I decided to help him with. He isn't very technically savvy so I thought I would give it try (good challenge). I have a JVC S-VHS VCR that I don't want to damage so I am going to clean his tapes first before trying any conversions. I have seen some automated cleaning systems but most are too expensive except the Kinyo UV-230C. I doubt the Kinyo cleaner will do much but I was thinking about hand cleaning using this method I found at Answer Bag (using distilled water) and then running to the Kinyo also. An old Videohelp discussion is similar to the Answer Bag one. Anyway if anybody has any good suggestions or techniques it would be greatly appreciated.
http://www.kiva.org/about -
Imo if you do this manually you're a long way to clean it 100%. It'd be better to build a simple system with a motor ,slow speed (10-40rpm max perhaps) but still faster than manual) and attach something to the motor that fit the forward/rewind holes of your tape.
Then for cleaning with the distilled water you'd need to have coton swabs on both sides of the reel..you get the picture.
Food for thought i hope*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36 -
Flood damaged tapes
By Theresa in forum RestorationReplies: 3Last Post: 23rd Jan 2011, 04:38 -
Can VHS tapes get damaged by HDTV magnetic field?
By Pixelrage in forum MediaReplies: 7Last Post: 16th Aug 2010, 00:22 -
Converting Damaged VHS Tapes to Files on a HDD
By RhoXS in forum Capturing and VCRReplies: 5Last Post: 20th Feb 2010, 09:40
