I am using Philips 5960/37 to play .avi file. It could not play some of the .avi file w/ saying "Video GMC not supported". I use Media Info to say the info about .avi. It shows that those .avi file is composed w/ GMC. What does "GMC" mean? do I need any updated firmware to play it? Thanks.
GMC = Global Motion Compensation. You will need to re-encode to remove it.
He's a liar and a murderer, and I say that with all due respect. -
Originally Posted by mats.hogberg
Anywhere from about 1/10 the running time of the video to 10 times the running time of the video. Depending on frame size, Xvid vs Divx, the settings used to recompress, the speed of your computer, etc.
On my system, about 40 fps processing speed using AviReComp.
/Mats -
Some examples with VirtualDubMod, fast recompress, single pass constant quantizer (3), output frame size equal to input frame size, input was Xvid AVI, both encoders set to 2 cores, Core 2 Duo E6300:
624x352 frame, Divx 6.5x:
fastest: 142 fps
balanced (default): 105 fps
insane: 33 fps
624x352 frame, Xvid 1.2x alpha:
default (MSP=6, VHQ=1): 34 fps
slowest (MSP=6, VHQ=4): 25 fps
320x240 frame, Divx 6.5x:
balanced: 339 fps
Philips DVP 5960/12 reports GMC NOT SUPPORTED
By sound grammar in forum DVD & Blu-ray PlayersReplies: 11Last Post: 2nd Apr 2009, 20:27 -
Bought New Philips DVP5992? Video Codec Not Supported?
By sandman423 in forum DVD & Blu-ray PlayersReplies: 15Last Post: 19th Oct 2008, 15:59 -
Philips 5960 again
By ripkirby in forum DVD & Blu-ray PlayersReplies: 5Last Post: 31st Jan 2008, 10:35 -
how to watch avi on my Philips DVP-5960
By woodsman in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2007, 07:36 -
silly question about subtitle for Philips 5960/37
By ididit in forum SubtitleReplies: 7Last Post: 11th Sep 2007, 18:02
