This "dxva_sig.txt" is created every time after I played an avi file and I had to manually delete it, is there any way to "NOT" have this "dxva_sig.txt" file AUTO generated? (I'm using ffshow).
Thanks.
I've seen several fixes, depending on your software.
This thread from our archives may give you some ideas: https://www.videohelp.com/forum/archive/t279694.html
Or this thread from Doom9: http://forum.doom9.org/showthread.php?t=99428
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
What Vdub filter can get rid of the green "Ghosting"?
By Brainiac in forum RestorationReplies: 5Last Post: 3rd Sep 2009, 18:08 -
:?: Vegas Pro 8.0 - How do I get rid of these "blocks"?
By YouTubeHDHacker in forum EditingReplies: 1Last Post: 6th Dec 2008, 16:19 -
How Does One Get Rid Of A Bug Known as "virtumonde"
By mysts in forum ComputerReplies: 32Last Post: 25th Nov 2008, 23:55 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 19:02
