Just filmed another High School Musical.... this time I brought my Cassette Deck and plugged right into the SoundBoard and recorded onto audio cassette tape....and got direct audio off the Mics used in the Show.
I'm back home now...starting the editing process....and need to capture the audio into WAV and then synch the audio up. I have my Cassette Deck plugged into my LINE-IN on my PCs SoundMax Audio Adapter/PCI Card.
QUESTION: What programs do you suggest to CAPTURE the audio and render it into WAV? (a free program possibly)
***It MUST be a WAV format because my Sony Vegas will only import WAV audio (or atleast thats the only way I've figured out how to import an audiotrack).
Please help and give your opinion
				Results 1 to 9 of 9
	if you have vegas -- you can record it with vegas - see your manual ..
 just arm a track for recording - after setting up where you are recording from .... then go ...
 works perfect"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
	Audiograbber 1.82
 Use the line-in feature ... works great
	Originally Posted by BJ_M i couldnt figure-out how to capture just audio-only from my TapeDeck.... while in the VIDEO CAPTURE sub-program. i couldnt figure-out how to capture just audio-only from my TapeDeck.... while in the VIDEO CAPTURE sub-program.
 so are you saying to INSERT an audio track and then record from within the track and DONT go into Video Capture?
 I'll read my instructions....
	i can hear playback thru my PC when playing the cassette tape.... I armed the track and recorded...NOTHING.... got 10secs into it and noticed the LED bar was not showing any audio.Originally Posted by BJ_M
 went into Options > Preferences > Audio Devices > Default audio recording = SoundMAX Digital Audio > went into Advanced = showed SoundMAX as Input and Output.
 After ALL THAT...... ******* nothing gets recorded.... WAV file is SILENT....
 I went out and installed AUDACITY.... simple, fast and WORKED the 1st time.
 Thanks for you help BJ but I'm using audacity now becasue it's an easy no-brainer kinda software.... with Vegas the stars and planets have to be aligned for it to work.
  Best way to extract audio from old Cassette tape?By Han Solo1 in forum AudioReplies: 5Last Post: 28th Sep 2010, 21:45
  Capturing cassette audio - convert to wavs - will this work?By Theresa in forum AudioReplies: 12Last Post: 16th Aug 2009, 04:33
  cassette audio tapeBy zoobie in forum AudioReplies: 7Last Post: 4th Jul 2008, 00:06
  Better method for cassette to wavBy socool135 in forum AudioReplies: 18Last Post: 16th Apr 2008, 13:29
  Broken Cassette Tape RepairBy SCDVD in forum Newbie / General discussionsReplies: 8Last Post: 11th Nov 2007, 12:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
