i am encoding with ffmpeg, only because i couldn't have luck with mpeg2enc, and i've gone through the whole routine with pull the m2v file and and mux them together. The output file is perfectly fine and the quality is amazing, but on my tv the ratio seems a bit off.
it looks like it has been stretched up just a little bit.
can anyone suggest what i may be doing wrong?
cheers
You may be missing letterbox bars, as your source file is wider than 16:9.
The easy way to add the black bars in ffmpegX is to check Decode with QT AND Letterbox in the Options tab. The amount of padding that is needed will be calculated for you.
First check if your source file plays well in QuickTime Player, as Decode with QT may fail if it has problems playing the video (missing components, etc.).
The hard way to add the black bars in ffmpegX is to NOT check Decode with QT, but use the Letterbox fields in the Filters tab, for which you have the calculate the padding (for your source file it would be [62,62,0,0]) and subtract the padding from the video size height (480-62-62=356).
Encoding with 'decode with ffmpeg' instead of 'QuickTime' is 10% faster (on my machine), so there is a speed trade-off for ease of use.
Here's a little calculus to get the letterbox value. I hope it makes some sense to the readers.
You want to get a 16:9 DVD
[calculate:] final.aspect.ratio = 16 / 9 = 1.77778
To get your wider movie in a 16:9 frame, imagine putting bars on top and bottom, creating a larger frame with a new height:
• unscaled.letterboxed.height = source.width / final.aspect.ratio
[calculate:] unscaled.letterboxed.height = 576 / 1.77778 = 324
Your movie covers a certain part/fraction of this 16:9 frame's total height:
• movie.fraction = source.height / unscaled.letterboxed.height
[calculate:] movie.fraction = 240 / 324 = 0.74 (=74%)
Both letterbox bars combined are the opposite fraction:
• two.bars.fraction = 1 - movie.fraction
[calculate:] two.bars.fraction = 1 - 0.74 = 0.26 (=26%)
Each bar is half of that:
• one.bar.fraction = two.bars.fraction / 2
[calculate:] one.bar.fraction = 0.26 / 2 = 0.13 (=13%)
Multiply by target height to get a pixel value for the letterbox bars:
• one.bar.pixel.height = one.bar.fraction * target.height
[calculate:] one.bar.pixel.height = 0.13 * 480 = 62.4
Manual padding in ffmpegX needs to be a whole and even number:
[calculate:] one.bar.pixel.height = 62
(Note that when calculating like this, the amount of scaling and the pixel aspect ratio are irrelevant, meaning it can be applied to just about every letterboxing job.)
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 18:31 -
Aspect Ratio Help
By darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 03:53 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 14:30 -
aspect ratio being a BIT%^
By llmercll in forum Video ConversionReplies: 13Last Post: 9th Mar 2009, 11:16 -
aspect ratio help
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2008, 14:41
