I have made a DVD using Muxman. It contains neither menu nor chapters. Is it possible to insert menu and chapters without loosing the subtitles?
Thanks in advance.
Hi-
You should have created the chapters when muxing in Muxman by going File->Import Chapter. If this is from a retail DVD, get the celltimes.txt and use that. When done, open the original DVD in VobBlanker and use the "Replace" button to replace the original DVD with your reencoded one. That'll keep the original menus and also the subs.
If this is a DVD you created yourself from an AVI or other source and you want menus, and you don't have the Pro version of Muxman, then it's better that you use some other authoring program to author with menus. I use DVDAuthorGUI. Others prefer GUIForDVDAuthor. They'll require that the assets (video, audio, chapters, subs) be demuxed (I think).
I believe TDA accepts VOB input. There's a free trial available, although it's a commercial product. I don't know if it can create chapters without demuxing, but I doubt it. My guess is that it's going to demux in any event.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Inserting menu into DVD without recoding?
By pericaa in forum Authoring (DVD)Replies: 4Last Post: 8th Dec 2009, 09:09 -
inserting a menu with chapetrs
By scamperoo in forum Authoring (DVD)Replies: 6Last Post: 22nd Feb 2008, 19:38 -
how to recompile customs menu to authored dvd?
By nick101181 in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2007, 17:11 -
DVD with no menu and just chapters
By marshyman in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 17:36
